Good evening folks.. It was a beautiful day here yesterday. I took the Titan and had it washed while out running some errands yesterday. I had the truck parked in the garage after returning home. I was doing some cleaning in the garage when I noticed a few spots of antifreeze on the garage floor. I pulled the skid plate and saw the fitting for the transmission cooler was leaking. This is the line on the side that the lower radiator hose comes out. It was leaking at what appeared to be where the fitting screwed into the radiator. I didn't have my reading glasses on and looking at this fitting close up, it looked like it screwed into the radiator. I grabbed an adjustable and thought that I would try to tighten it up. I turned it a little bit and suddenly it got a little looser. Things didn't seem right but the leaking stopped. I started up the truck and within 20 seconds I heard antifreeze pouring out from under the truck. I shut the truck off to find that antifreeze and tranny fluid was pouring out of the overflow tank. Fast forward to last night. I acquired a new replacement radiator and replaced the old one. I flushed all of the old antifreeze and transmission fluid out of the cooling system and refilled. The transmission is a different story. The fluid is milky and that is why the truck has not moved. I have not driven it since I broke that line in the radiator. I will not drive the truck either. I am totally responsible for this. I am very mechanically inclined but still made the mistake of trying to tighten a fitting that I should have left alone. I really wasn't thinking that the line was a transmission line. Now I have to deal with this. I've read the DIY transmission flush. Is that procedure good enough to and reliable enough to remove all of the old transmission fluid? OR. Should I just have it flat bedded to the Nissan dealership and have it professionally flushed? This truck is an 05 with 84,600 miles on it. I want everything to be alright and not have to worry about the transmission. Thoughts??
Thanks!
Thanks!
