1 - 16 of 16 Posts
I have 4 10" kicker comp vr's that are 5 1/2" in depth total, and Im wondering how I can fit either all 4 of them under my back seat, or put to under the back and 2 under each front seat, either way Im going to need something to raise the seat up... can anyone help me out?
Supporting Vendor (Gold)
These subs will not work under the front seats. You can physically fit all 4 of them under the rear seats but there is not enough airspace. I assure you 2 of these subs under the rear seat will be better than all 4. Use 2 and sell the others or keep them as backups. Or use all 4 properly and lose the back seat.
how could all four physically fit under the rear seat??? and if there is absolutely no way to get the airspace needed you can always port the box right?
4 could not fit, properly.
What he was saying is that because 4 would require more airspace than you have 2 in the proper airspace would sound better. If you port and enclousre you actually need more airspace than sealed to make it sound right.
do you know if theres a way to lift the backseat up so it will still work properly and be able to fit the subs under there like a box for 2?
James can build you a box that will make 2 work well. However there just isnt enough room for 4 unless you remove the back seat, or make special mounts to raise it quite a bit. A few people have made brackets to do this but nobody makes a kit that you can buy.
4 10's can PHYSICALLY fit under the rear seat. TRUST ME. You only have enough airspace for 1 sub if you go ported.
Discussion Starter #10
haha okay smartass.... im talking in depth here, I guess I'll have to raise the backseat about 3 inches... Ive talked to a professional audio installer and thats the only thing we could come up with considering I dont want my **** ghetto lookin or anything..
Upfire the subs. No need to raise the seat. They are under 6" deep. I've been installing for 13 years.
Discussion Starter #13
yeah I was thinking about forward fire.... I appreciate the help tho I dont know what Im gonna do yet, I'll let you know when I have pictures up of my setup.
1 - 16 of 16 Posts
