1 - 20 of 20 Posts
homeboy58
Discussion starter · #1 ·
I'm looking for pics of any titan with 20x10 in. rims. I'm looking to buy a set and run 305/55/20 tires if they fit a 10"rim. I have a PRG 2" leveling kit. Not sure if thats enough lift. any pics would be appreciated.
depending on your offset they may rub a little. I know I had to "trim" to get my 33"s to fit after a 2.5" leveling kit. But my wheels have the worst offset ever.
Discussion starter · #3 ·
I think the offset is -25. That truck is awesome!
I have had some rims that were only 8.5 wide and worse then the helo's . I like the blacked out helo look though.
Discussion starter · #5 ·
What type of fenders are you running on that beast?
Im running 20x10 with 33"x13.50 tires with a 6" lift. I get a little rub when turning sharp and going on a big bump(at the same time, so not very often)
I don't believe a 20x10 -25 offset wheel will fit with your setup. I wanted 20x10 as well but I had to settle on 20x9 0 offset with my mini lift. I choose a 305/60/20 (34.5x12x20")toyo tire and it doesn't fit. I'm going to try the pinch weld mod and cutting the lower fender this weekend.
Discussion starter · #10 ·
Yea its looking like 10" is going to be to wide. probably go with 9" width.
any tire size suggestions?
Discussion starter · #12 ·
Offset is a +20. So u think I can fit the 305/55/20?
I have 20x9 or 9.5 MB motoring smooth (bought them used) with 305-50R20 toyo open countrys on a 2WD with 2" leveling kit and they did not rub, BUT I did not offroad with them, so my suspension never saw full compression with wheels turned. If you are just using them on the highway you should be fine IMO
Discussion starter · #14 ·
got any pics of that set up?
check out mazzi hulk rims they are discustingly sick!!!!!
20x9 w/+20mm offset should clear. I have 20x9" +18mm offset and it would've cleared 33"s w/leveling kit, but I have a body lift also so I have 35"s. they just barely clear, in fact one side I have to redo the pinch weld... I have a 4wd w/2.5" leveling kit and 3" bodylift... so like I said, +20mm offset w/33"s should clear with only a leveling kit. may need to so the pwm also. then it'll definitely fit ;)
I love those black widows on a black truck too... sickness... I actually like my rims, and only find a few I'd like more :)
Discussion starter · #17 ·
thanks thats some good info any other pics of your setup?
I have 20x9.5 zero offset with 305/55's. 2" leveling kit as well. I have done a little trimming but still get a little rubbing here and there.
I got my 20x9 0 offset/5" backspace and 305/60/20 toyo ATs to fit. I cut the pinch weld and the lower fender off. I doesn't rub around town I have not tried it off road yet.
1 - 20 of 20 Posts
