Im runnind with AFE which has the snorkle wrapped the tube with high heat header tape and then a silver self stick to finish,its good throttle response and sound and MPGs im getting 15-17 all aroundLooking into performance intakes that sounds good and hopefully improve gas mileage as well.
Most cold air intakes are routed over or along engine components which for the most part will heat the intended (cold air) thus wrapping the tube to the best i can.Ive done this on other trucks with varying results,mpg`s throttle response with improved resultsThats dope, looks good too. I assume the boxed in air intakes are better for the Titans to prevent heat soak…?
