1 - 13 of 13 Posts
You are kidding aren't you?
It has product in most auto parts stores. Cleaners/Additives etc. Advertised in Hot Rod magazine when I was a kid in the 60's. Well established company.
My wife worked for them for a short time. That has to be one of the most disorganized businesses I have ever heard of. Their product on the other hand, speaks for itself. Their filing system is royally screwed up.
the dealership i used to work for used wynns....it was great stuff!
I doubt that it includes the fluid for that price. And yes it does matter if it's not Matic J. It's the only fluid you can use in your trans. except I think there are some post here that mention another brand that will work.
At one time, their "Friction Proofing" was forced off the market because no one else could match it. I used to use it and would again if I could find it. Pep Boys was the only place I could find it and they stopped carrying it years ago. I use Lucas now, but it's not the same. After a few treatments of Wynns', my engine started easier, ran cooler, and I had to adjust the idle down b/c it climbed from less friction.
Discussion Starter · #12 ·
well the guy who has the wynn system does not have a atf that is compatable with the matic J nor does the stealership have a flush machine!! I talked to the guy at AAMCO and he said if I bring the fluid he will change it out for $40. I can get matic J from California cheaper than buying it here!! He also said he does not believe in doing "flushes" with a flushing type product because some of it always gets left behind. The stealership will do a drain and fill for $89 which changes 4-5 quarts I think so now I really do not know what to do. Any ideas out there.
TitanTech659 said:
It's pretty good stuff but IMO BG is probably the best stuff I've ever used.
x2
BG 44k works great cleaning out all the crap that the stupid ethanol leaves behind. And the transmission flush has always worked for me.
And BG actually guaranteed their product if you start using their services when the car is under factory warranty.
1 - 13 of 13 Posts
