I have an 08 2WD that sat 35" stock. I currently am running the Bilstein 5100 on the top setting, which has me sitting at 37.25" after settling in.
I am in the process of picking up the 08 4x4 springs which I want to pair with the Bilstein (prefer to set them at 1) and possibly a 1.5" spacer. So...
08 springs (1.5") + Bilstein set at 1 (1.5") + 1.5" spacer = 4.5" lift.
Anyone else with a 2WD try a spacer with the Bilstein set at 1? I don't mind if the coil bucket contact is minimal. I'll just grind down the lip a little. As far as I can tell, the position of my 08 coil bucket isn't different from my 06.
EDIT: I know most go with the 08 springs + Bilstein 5100 set at 0 + 1.5" spacer without any issues. Since adjusting the Bilstein only adds to the preload, I don't think it would cause any contact issues.
