I bought my Titan brand new in 2004 and installed a plow on it that winter . I am most likely the first person with a plow on a Titan. I posted your exact question on this forum and had alot of negative feed back. Well after 6 years (5 winters) with the plow i am proud to say that this truck is a great plow truck. Recently the truck started riding like **** and i figured the plowing was starting to takes its toll. Turned out to be worn u-joints , replaced the u-joints and installed some new tires and my baby rides smooth as silk again. Only advice i can give you is to install a set of PRG's front coilovers , i installed the donahoe's for a $1100 ( they give you the lift you need in the front and are heavy duty yet ride great ). They also are durable , the stock front struts were toast after the first winter plowing. I made close to $35000 in the 5 winters i have the plow. Fronts struts , u-joints , tires and a new battery in 6 years ( knock on wood :bangit: ) Dont be afraid to put a plow on...
