1 - 10 of 10 Posts
just wanted to know what size tires everyone was running. i have an 07 cc 4x4 with the 6" and am currently running 35x12.50x18's but they look to small for he truck. help me out!!
I got the same problem with my tires. The biggest issue i think would happen if the switch was made to 37's is they would rub pretty bad on the bumper and fender. Most people don't believe me when i say what size tires i have cause the truck makes them look soooo small.
Glass................................:teethmast
Foxdelta has 37-13.5-17's on the factory off road rims with a 6 inch lift
i think im gonna try my freinds 37s on 20 when i lift mine pro4x 6 inches i hope they clear"idhitit2:
nope u gotta cut ALOT, stack a leveling kit on top of your 6" lift which is fine and still cut some or body lift! Or...run fiberglass fenders! A 6" lift rubs some on 35s on the inner fenders so 37s would def hit!
On top of the 6" lift, I think Foxdelta has SAWs cranked up in the front and Deavers and Bils in the rear... and some trimming maybe
yep - I got 37's with just a 6 inch lift - never even did the pinch weld mod - less than an inch of pre-load on my SAW'S. I have several posts with pics. They do rub a little - it amounts to a quarter size spot on the inner plastic fender and does not inhibit travel. no rubbing on the front bumper (when I had one)
EDIT: still have stock UCA's as well
Nice! It'd be cool to rock 37's w/o the PWM and/or trimming. I need SAWs first tho.
Discussion Starter #10
well see mines not a true suspension lift. im rockin the rough country 3" level with a 3" body lift and a 2" rear block. i cant find someone with 37x18's to try em so i figured id ask. i might just go with the interco 35x14.50x18's and just be happy with my tiny tires:crying:
1 - 10 of 10 Posts
