1 - 14 of 14 Posts
Anyone running 305/65r18 tires? approx 34" if so did you have to have mini lift? pics please?
Super Moderator
I'd say you would at least need the level kit. You might not need to lift the back like with the mini lift, but the front spacers would seem necessary in that case.
This is all I have at the moment, I can get some more in the morning. They only rubber till I got home, but I did the pinch weld mod and that solved the problem, but then I ended up getting a leveling kit installed on the following weekend.
Discussion Starter #4
more pics and airbag pics also. i tow a 7000#lb camper
I'll get them up this afternoon, I thought my camera was in my desk at work but it must be somewhere at home because it wasn't here when I got in this morning.
Took longer than I thought, but here are the pictures they are all mixed together. if you need any more specific angles just let me know, while i'm still at work
Right air bag 10psi
10 PSI in Airbags
100 PSI in airbags
Right airbag 100PSI
Left airbag 100PSI
side view
Compressor under rear seat
wheel view
truck side view
Compressor
gauge in center console
Discussion Starter #7
so the airbags raise it about 1.5 inch? how much did the air bags help with tow sway? and with the level kit can you still run the mud flaps?
do you have a front and back pic? i love the way it sits.
The airbags give me about 2 1/4" of lift, they helped with the heavy tongue weight of my trailer and they also help with the sway but my trailer is only about 20’ so sway is only minimal.
I took my mud flaps off before I even got the tire, but they would not stay tight and were rubbing the paint off. The back ones would fit but the fronts wouldn't unless you did some trimming to the mud flap
Would those tire's fit on a stock 2WD Titan w/ no lift at all ? If not, what about just a leveling kit, will it rub ?
Thank you
very nice truck by the way !
It will fit a stock 2wd with the pinch mod and no lift/level kit and if you have the level/minilift you don't have to do anything at all. I have those on stock rims and the mini lift and it looks awesome!
Thank you
Thanks, you will get rubbing, but like scrubbyoy said all you need to do is the pinch weld mod and heat the fender liner and problem solved
Here’s a picture where they rubbed
1 - 14 of 14 Posts
