I have an '04 Titan with 316,000 miles on it. Back in 2013 I installed JBA long tube headers and the Cajun B-pipes with high flow cats. Easily one of the best upgrades I've done to the truck (along with the Uprev tuner).
So it's been about 200,000 miles since i did that install. I've been getting P0420 codes over the last three months. I was gong to switch out the downstream sensors; moving bank 1 over to bank 2 and vice versa. As luck would have it, I cannot get the O2 sensors out without removing the b-pipe altogether. So I've decided to remove the pipes this weekend and go ahead and replace the downstream sensors on both banks with brand new ones that I just ordered off of Rockauto.com, as well as replace the gaskets with new Nissan OEM replacements from Courtesyparts.com. There's no guarantee that replacing the downstream sensors will resolve my problem as the cats might just be worn out.
So here's my question: when i remove the b-pipes, assuming the honeycomb looking stuff inside is fully intact and there's no loose debris, should I try cleaning the cats via an overnight soaking in water and Dawn dish soap? Has anyone tried this on the Cajun catted b-pipes (I'm NOT looking for feedback on any other aftermarket brand)? If so, did it make a difference?
Thanks in advance!
Thanks in advance!
