Just finished moving into Burbank and I don't have access to my tools (or a lift) and I wanted to get the mid travel installed (cheap if possible) Plus my new driveway is sloped and I don't feel like having the truck roll off the jack stands.
If you guys know anyone let me know please
Ball joints are already pressed in and I have extended lines on already so all that needs doing is swapping out the upper and lower arm and the tie rod extension.
Discussion Starter · #2 ·
So if no one wants to install it how about lend me hand and some tools?? I know some of you guys have to have have a good set up! As Spicoli would say "Man we can fix it! My dad has an awesome set of tools!"
You should have Nick throw it on there next time you are down in SD. He gave me a good deal.
I was thinking of asking him as I need to have straps installed also, I just figured he was to busy with your project and I don't know how long the entire thing would take.
Are you running shock hoops or going to still use the factory coil buckets?....What's been done to you suspension as of right now?
I get to ask all these questions because I live in Burbank.... :)
Discussion Starter · #6 · (Edited)
Heya Lou
As of right now I am just running Saws and the CST lift spindle and the Deaver C-30 in the rear. As far as shock hoops No not yet but when my Dirt bike sells I will be putting in some 10"s and shock hoops. I also have custom traction bars on the rear if that mattered to you. Oh I also have the CST upper control arms.
PM me and i'll take a look at what you have....:)
