Went to go get my tires aligned and they told me my upper and lower arms were worn out and if I wanted the alignment to stick I should replace them. I drive an 04 LE 4x4 anyone know any good brands or places to buy from?
PM a good Price Nick! Total Performance is selling them for $498! i'm ready to buy here quickly!If you are looking for something that you could run with a lift later on we offer two styles of upper control arms for the Nissan Titan. They both allow for more lift (or additional travel when used with after market coilovers) by allowing more clearance over the coil bucket. They eliminate the loud clunk from CBC (coil bucket contact) that you get when lifting these vehicles.
Bushing Style Upper Control Arms
After seeing the issues with other bushing UCAs we decided to develop a competitively priced and functional UCA. These UCAs feature polyurethane bushings and heavy duty Moog ball joints. For proper fitment our polyurethane bushings are custom machined to clear the rounded corners in the pocket. This will help prevent noise and extend the lifespan of the bushings. The outer bushing sleeves are made from 2.25" .250 wall tubing and gusseted for additional strength. They include zerk fittings allowing you to service them. The Moog ball joints are completely sealed making them ideal for harsh weather conditions. Most importantly our UCAs have increased castor and additional clearance for lifted or extended travel applications. The increased castor is needed to keep the vehicle within alignment specs when raising the ride height. The arms come fully assembled and include detailed instructions making installation quick and easy.
Includes:
• Chromoly upper control arms
• 90 degree zerk fittings
• Custom machined polyurethane bushings
• .250" wall inner bushing sleeves
• Moog upper ball joints
Additional Notes:
• Maximum wheel backspacing: 5.25"
• 2WD and 4WD compatible
• Works with factory or aftermarket coilovers
• Designed to clear the coil bucket for maximum lift
Compatibility:
Nissan Titan 2WD/4WD 2004-2015
Nissan Armada 2WD/4WD 2005-2006
Nissan Pathfinder 2WD/4WD 2004
Link to our website for more info and pictures Nissan Titan Bushing Upper Control Arms
yes it is but i'd like to oder from Nick if i could!thats a good deal on uppers.
well damn! Maybe Nick will hook me up! what about it Nick?!Too bad you missed this...
http://www.titantalk.com/forums/tit...irt-king-upper-arm-group-buy.html#post6795729
Yes I would definitely be able to help you out. Sending you a PM now.well damn! Maybe Nick will hook me up! what about it Nick?!
Agreed, these things are solid. Now if only I could afford lowers...Love my DK bushing arms!
ugh...$1400 tho? for a street paver? occasional running over some pebbles or two here in OHIO LOL!they are sick. and they do look good. they also work GREAT. i love them.
