Ditto this question. If it's an air compressor to run air wrenches, fine. But if it's a spring compressor, you're doing it wrong. :lol:Compressor?? What kinda compressor?
You don't need a spring compressor to install a leveling kit. However an air compressor and air tools makes the job a lot easier.
Twin sons.Ditto this question. If it's an air compressor to run air wrenches, fine. But if it's a spring compressor, you're doing it wrong. :lol:
It's all good, u gave a response.My bad! :teeth:
For some reason I thought you were also swapping out the suspension as well.
None. ..............Any problems with just adding a 2" leveling kit and not upgrading anything else?
Yeh of course....you'll have to sit there and come to terms with the fact that you only upgraded ONE THING!!...trust me I suffered from that once...lol!!It's all good, u gave a response.
Plan on putting it in on friday. Wish me luck. Any problems with just adding a 2" leveling kit and not upgrading anything else?
Sent from Goree's iPhone using Autoguide
Rear block won't help. for the older model Titans 2" for 4x4 and 2.5" for the 2wd, but for newer models, 08+, it's 1.5" for 4x4, and 2" for 2wd. You might be able to grind away enough of the coil bucket lip to clear ... look for the mark from the UCA, grind a U with a Dremel tool etc. spray paint, drive, look for new mark, repeat.Already purchased 2"I guess i will install it and give it a run. If i put a .5" block in the back, would that help? or does anybody want to trade a 1.5" for 2"? I was told you could do 2" on 4x4 & 3" on 2WD without having to do anything but add spacers. Is this incorrect?
