so I was having some transmission slip issues and after checking my transmission dipstick I found no oil on the dipstick, surely that must be the problem. so today I picked up 5 quart and came home to do the spill and fill. i got about 2 3/4 quarts out of the pan when i drained it. as i refilled it is stopped after adding about 3 3/4 quarts to check the level(with it running obviously), and there was still nothing on the dipstick. i then said screw it and added the additional 1 1/4 quarts that i had. i rechecked the level on the dipstick and realized that i had quite a bit too much and it was at least a half inch over the range on the dipstick. my question to you guys, is it okay that i added maybe 1 quart too much ATF fluid?
