1 - 3 of 3 Posts
Just bought an '04 titan LE crewcab. Previously stolen and had aftermarket navigation unit in it. It was cut out so now trying to find harnesses to put back in. Has tweeters, center channel, sub under the drivers seat...would this have been a factory Rockford to share system? DVD entertainment unit as well. Trying to piece back together
That would be an R/F unit, yes. Your faceplate should look like this:
It says "Rockford Fosgate" on it.
Are you trying to return it to stock or just wire up another aftermarket head unit?
I am sure there is a wiring diagram somewhere that would help you wire up another aftermarket unit. But i am not sure if the R/F units had an OEM amplifer which you would need to either convert the signal so it can remain (i have done this in my BMW for aftermarket subs) or try and bypass it (which will lose the power to the sub and center channel)
1 - 3 of 3 Posts
