1 - 8 of 8 Posts
Has anyone looked into auxiliary gas tanks for the Titan (non-XD)? I tow quite a bit and the 26 gallon tank just doesn't cut it.
I've looked into several but most that you find are for Diesel. Just thought I check here to see if anyone had gone down this route yet.
Thanks,
--CM
When u pullin’ a 20 or 30ft travel trailer last thing u want to be doing is navigating a busy gas station any more than u have too..
It's not that bad. I see people do it all the time.
Dual tanks kinda disappeared years ago. Mid 90's or so I think. Probably needed them then when gas mileage was worse and smaller tanks were used on trucks. Not only that...twice the probability to have problems...2 fuel pumps...more gas lines...a changeover valve...not worth it.
It also reduces available cargo capacity and tongue weight as the truck will weigh substantially more. I do understand why you’d want to fuel up far less often.
Clint
1 - 8 of 8 Posts
