I have the same issue with my 07 XE.
Okay thanks! I had an 05 XE it never did this. But I also didn't buy it new.There was a recall for something like this on 04 early 05. Might be the same. Try a search and look at some of the old threads.
Have you ever had it looked at?I have the same issue with my 07 XE.
What year was yours? I posted it on instagram and a guy with a 2015 said it happened to him that day. It seems to be hit or miss what titans have the issue. Like its a bad design of a part mixed with bad product control when making them.I had the same issue with mine when it was really low on fuel. Something is causing an air pocket.
I know that seems to prevent it, I just don't want to use that as a solution for the next 10 years. I will thank you!!My 04 has done this forever. Try filling your truck slower and keep at least a quarter tank of fuel in your truck. I forget exactly what the part is called ,evap vent control valve I think. It's a box located next to the gas tank and filler tube.Here is a write up on it but the pics are missing.http://www.titantalk.com/forums/tit...m60b-evap-vent-control-valve-assy-sticky.html
I will, thank you!There was a recall for something like this on 04 early 05. Might be the same. Try a search and look at some of the old threads.
No not yet. At first I thought it was just the gas station I was using.Have you ever had it looked at?
Mine is a 2012. I agree, it only happens if down at E, seems fine if at a .25 tank or more.What year was yours? I posted it on instagram and a guy with a 2015 said it happened to him that day. It seems to be hit or miss what titans have the issue. Like its a bad design of a part mixed with bad product control when making them.
Yeah which only seemed to baffle the tech even more. Mine seems to be related to colder weather, it started this time last year stopped for months as soon as it went from 75 to 50s started again.Mine is a 2012. I agree, it only happens if down at E, seems fine if at a .25 tank or more.What year was yours? I posted it on instagram and a guy with a 2015 said it happened to him that day. It seems to be hit or miss what titans have the issue. Like its a bad design of a part mixed with bad product control when making them.
Mine seems to do it in waves, I actually thought it was a valve that finally worked it's kink out and stopped sticking. Then after 6 months it started back up. I'm a 1/4 tank right now. I'm going to run it until E and see what it does this round.My '08 does the same thing, but usually only once every now and then (months apart). Once I slowly get it to about 3-4 gallons I can let it go and it fills up the rest of the way. Only time it ever bothered me was when I used 30 cents off at Kroger and walked into the store to buy a drink or something and it shut off after 1 gallon long enough for the pump to reset.
I always run it to E in the summer, it doesn't have the back flow issue until the weather gets cold. When I don't usually let the tank get below 1/8-1/4. Even the nissan tech said he runs his to E also.It's good practice to keep at least a quarter tank of gas in your truck for several reasons. One being your fuel pump will last longer because the gas in the tank is what keeps the pump cool especially in the summer.
