I have a backup camera issue that I just can't seem to figure out. When I put my truck into reverse the camera will display for like 20 seconds and then the screen goes all black and only shows is the grid lines. If I put in park and then in reverse again it will not show back up again unless I turn the truck off and back on again and the camera will then display but again for only a few seconds.
- I have checked the wire harness in the tailgate and it seems fine.
- I replaced the rear camera - same exact issue
- I even swapped out the head unit with another working unit - same exact issue with the other head unit.
- I have reset both units to factory and pulled the negative terminal on the battery for a full reset. - same issue
I am running out of things to try. Now someone also had this same issue but has never responded with a fix for it.
Backup camera
The backup camera in my 2018 Titan has stopped working. Sometimes it comes on when I put it in reverse but only stays on for a few seconds before the screen goes black. If I press the camera button I just get a screen that lets me turn the grid lines on or off. The dealer can't figure out where...
www.titanxdforum.com
If anyone knows of a fix for this I would be greatly appreciative if they could share the solution. Its a very aggravating issue when you rely on the camera.
