Hi folks,
Well I finally got sick of not having my backup sensors due to a fault, so I ran the diagnostic and it said outside driver side sensor malfunction. I got under there to take a look, and discovered that the green wire going to the sensor connector was broken off right at the connector. There is still a stub of wire stuck in the connector, but it is not long enough to splice the wire. Do any of you electricians know if it is possible for me to pry out the stub out of the connector or open it up somehow and just connect the wire back into the hole, or do I need to get a new connector and re-do the connections. Any help would be greatly appreciated. Cheers!
