Did you use a LOC to hook up your amps?
With the factory RF setup if you splice in the LOC before the factory amp the output signal is very weak and thats one reason you are probably getting a very low signal to your amp.
If you are ONLY going to hook up subs and leave the rest of the speakers stock I suggest you install your LOC at the plug for the factory sub under the drivers seat. If you loosen the seat bolts you can lean the seat back and get to the plug. This will give you a good strong signal for the LOC and provide a decent preamp for the P400-2.
If you have any more questions let us know.
