+1! so much easier and you get new ball joints and LCA bushings at the same time! also, it came with these grease nipples so you can always add grease to them!Easiest way to go is to replace the lower control arm , the OEM part comes completed with a ball joint and mounting bushings .
An alignment will be needed of course. Just get it close and then get it aligned .
