I had a problem w/my stock UC's hitting the coilbucket pretty hard at full droop (which happens on a daily basis for me).
I finally got out the dremmel tool this past weekend & went to work massaging the contact point. I really didn't have to remove too much material to fix the problem. All I used was a small drum style sanding attachment.
If any of you are having the same problem, this seems to be a relatively easy fix.
