I would get it welded. It's just the condensation dripping out from heat. Nothing big.
Ok....nevermind......i just had a brain storm and pictured your story.
I had to replace the Banks gaskets with the Nissan stockers as mine developed an exhaust leak after about a year. The stock gaskets are of much better quality then the ones Banks gives with their kit.MoValleyTitan said:All right guys, I've had the Banks installed since summer and I started to notice water dripping from one of the seals at the y-pipe, is this normal or does the seal need replacement? :huh:
WTF? Mine were about $9.00 each.tcf_dk said:This is a known issue with the banks system.I bought some gaskets from Napa since Nissan wanted almost $30 per gasket.Too cold to change them yet.
I don't think I would want to replace poorly made gaskets with another of the same. Did they upgrade them over the original Banks gaskets?crippeninc said:Call Banks, they will send you a new set of gaskets free of charge. They did for me.
37L1 said:I don't think I would want to replace poorly made gaskets with another of the same. Did they upgrade them over the original Banks gaskets?
