Sears does have the battery, but you may have to order it in order to get the terminals correctly oriented. They do have them. I have the one they "stock" at Sears, and it is backwards. The day after buying the Sears, I finally got a warranty replacement on my Odyssey the installer cracked the post on; and will use the Sears as a secondary battery.
FYI: Sears Platinum has:
A nice built in handle
930 CCA vs 925 CCA Rating (insignificant really).
Normal Top Post molded in vs Odyssey using threaded studs with adapters on top (Installer over tightened mine).
$190 for Sears, vs $300+ for Odyssey.
Sears has far easier Warranty service!
