1 - 2 of 2 Posts
2004 Titan
Letting my truck sit for couple of days,the battery will be dead. Dealer has replaced battery and leads,,BCM module,,and has the truck today to try to find the drain, It's happened 3 times since I got the truck 3 months ago. Nothing is really jumping out at us and diagnostics check normal.
ANY ideas on how to proceed???
Get a cheap DC amp clamp and start checking wires to see if you can find the issue. Or put it on the main positive lead to the battery then start pulling fuses until you find one that stops the current flow. Good luck and let us know what you find.
1 - 2 of 2 Posts
