I've been chasing a dead battery issue for months, involving buying a new battery, trips to the dealership, and my independent mechanic.
Numerous times I came out to a dead battery, the truck wouldn't unlock with remote and no interior lights after unlocking with key. It had sat a couple weeks so I jumped it and everything seemed fine. This happened two or 3 times, parts store tested my battery and said it was bad. So I bought a new one but the issues continued. I took it to the dealership to confirm the alternator recall was done (it was) and they tested the battery and charging system and said they were fine.
The issues continued and I attempted to trouble shoot it my self with no avail. I took it to my local mechanic and he said the battery was bad (only 5 months old, but it could have been bad off the shelf.) I took the battery back to the parts store, they charged and tested it and said it was fine. While leaving the volt meter up on the display screen I noticed it would drop below 12 volts when running the truck more than 15 minutes. I took it back to my mechanic, he was able to recreate this issued, confirm it was a bad alternator and replaced it. He said he tested it, and as well as the drive home confirmed the voltage stayed above 13 with the truck running. It sat for a couple days and the battery is now dead again.
I know the numerous drain and recharge cycles aren't good for the battery, but would it still take a charge and show good on a cranking amps test like its doing? Should I spend the money on a new battery even if this one isn't failing the parts store test, or is it more likely something is draining the battery? I wasn't able to find a short and don't have the best meter for doing this/ but neither of those appeared to be an issue when I checked. I'm pretty sure my mechanic ran those test the first time it was in as well.
