Anyone know the part numbers for the rear axle oil seal and the axle bearing? Thanks, Chaz
D Dr. Chaz · Registered Joined Apr 5, 2006 · 74 Posts Discussion Starter · #1 · Sep 20, 2007 Only show this user Anyone know the part numbers for the rear axle oil seal and the axle bearing? Thanks, Chaz
baseballfanz · Premium Member Joined Jun 4, 2005 · 17,446 Posts #2 · Sep 20, 2007 Only show this user Rear axle bearing (need Left and right) 40210-7S210 Rear axle seal (need Left and right) 43252-7S200 You might or might not need Rear axle spacer (need Left and right) 43070-7S200
B bighitter · Registered Joined Jun 11, 2005 · 484 Posts #3 · Sep 20, 2007 Only show this user Someone else doing the big tow upgrade? Those are the parts I used.
D Dr. Chaz · Registered Joined Apr 5, 2006 · 74 Posts Discussion Starter · #4 · Sep 22, 2007 Only show this user Thanks for the info, again, baseballfanz :thumbsup: I need to get the info together as I'll be replacing the OR carrier with a TT one of these days... The warranty clock is ticking!
