After alittle offroading today i was washin my T and notice the drivers side of the bed was sagging. Turns out i lost a body lift puck bolt and bushing. Anyone one know if i can get a bushing and bolt like that from autozone or somethig and if you cant does anyone know the size of the bolt so i can get one from home depot. I have the body lift puck.
Thanks
-Dave
Titan XD Diesel Pro4X
Thanks
-Dave
?????:dunno:?????? Not sure, but I am sure you could find one at a salvage yard, shouldn't be that expensive.
Body lifts cause much trouble in the long run if you take the truck off road
The reason I had the problem was because when installing the lift the nut welded onto the bed got stripped out so I could only torque it to like 20 pounds. Well I drilled through that nut and put a new one on top, torqued it to 45 pounds and called it a day. I also couldn't find a bushing that would work, the dealer wanted 45 bucks for it, I used an aluminum washer instead lol.
Some pics below.
