Depending on your weather you'll probably end up with bed rust in the long run. I had a factory bedliner in my 88 Nissan and sure enough, when I lifted the liner after 5 years, the area near the tailgate was all rusted. I know others that have had the same problem with their liners. And this is in So. Cal. too.willy said:I just got my titan about 3 weeks ago, and it doesn't have the bedliner.
Does anybody have any suggestions on if I should get a spray-in bedliner
(line-x, rhino linings) or a drop in liner. The prices are about the same.
thanks guys for the advice.ARCANGEL said:Thats why the spray on liners are the best no rust EVER!!!! :futwice:
If you do choose to go with line-x, write back and tell us how it went. I would like to know becouse I'm also trying to get a spray-in liner installed and would value the information. I have both rhino and line-x dealers avaliable and have yet to decide on which one to use. Thanks in advance for the reply. :cheers:willy said:thanks guys for the advice.
It's settled i'm going with the spray-in liner. probably the line-x, its $50
cheaper than the rhino linings.![]()
