1 - 3 of 3 Posts
Has anyone ever bent the bull bar brackets that connect to the frame? I got stuck last night and the only way to get me out was to tie on to the bull bar which got me out but in the process it bent my brackets. The bull bar is fine its just pitched downwards because of the brackets and it probably only moved about three inches. Does anyone know of a way to fix this without buying new brackets?
can we get pix? if it was mine id heat it up and bend it or maybe even beat it back in place. im not exactly sure wat the bracket looks like though.
Soory no pics I already fixed. It was actually very easy, all I did was lay on the ground and push it back with my feet and then put a little JB Weld on the hairline crack it put on the bracket. Thanks for the response though.
1 - 3 of 3 Posts
