Thank you for the lesson...I may go the way of 35 wat for the lowbeam, and test the 55W on the fog light..H1s are cheap, and there are a LOT of different brands. eBay has a ton of them. Pick one, try it. If you don't like it it's not a big investment. As for brightest, most you'll find are a 55w bulb. There are 100w types and 130w types as well. Each step up will put out more light but at a cost...More heat, and a higher amp draw. Higher heat could melt your housing, and the higher amp draws could melt your wiring harness. Your stock low beams are a 55w bulb, just to give you a reference point.
