1 - 3 of 3 Posts
I was wondering everyone's opinion from personal experience / use what is the best upgrade of brakes (rotors, pads, and if needed any other components) for the 2006 Nissan Titan King Cab LE 2wd with stock 18 rims, slightly larger nitto terra grappler tires and the PRG mini lift / leveling kit installed. I am about to do basically all new brakes and suspension so was hoping for recommendations from personal use etc. Thank you.
You don't need to double post.
For any pre-08 Titan, the first thing you should do is upgrade to the larger OEM calipers and rotors. There's a sticky somewhere on here about this big brake upgrade. It uses Armada rotors from a specific year. A search should hook you up.
1 - 3 of 3 Posts
