The '08 bumper caps are NOT the same as the '04-'07's. They're smoother in contour and the foglight openings are squared off on the sides. Also, the Armada front airdam that fits on the '04-'07 bumpers apparently won't work on the '08's.
Since the '08's are relatively new, not enough time has elasped for people to wreck them in sizable quantities to get a color choice. You can get a new bumper cap from Nissan and have it painted. Since you have an SE with the chrome center section, the color match shouldn't be a problem.
Have you checked Copart lately? They usually have a lot of new late model wrecked trucks. You never know, you might get lucky.
Thanks! I stand corrected. While the steel bumper underneath is the same, the end caps are cosmetically different.. an 07 cap will fit an 08 bumper but will look different and thus not much use to you if you are replacing just one.
