Good advice.If your still have the original struts up front. I recommend bilstein 5100s on middle perch (they are adjustable) will get you pretty close. Otherwise if your not interested in putting much money into it you can get a solid aluminum spacer to put between your struts and coil bucket (you can find them pretty cheap on ebay or check out buy/sell section here). Both options are safe, you will retain factory ride with the spacer, the bilsteins will improve it.
Cool, I was concerned that I would need more than just the Bilstiens to get it even.If your still have the original struts up front. I recommend bilstein 5100s on middle perch (they are adjustable) will get you pretty close. Otherwise if your not interested in putting much money into it you can get a solid aluminum spacer to put between your struts and coil bucket (you can find them pretty cheap on ebay or check out buy/sell section here). Both options are safe, you will retain factory ride with the spacer, the bilsteins will improve it.
https://www.amazon.com/gp/product/B00PKHY0S6/ref=ask_ql_qh_dp_hzabilstein's in the rear do not add height...they're just shocks. post a link to those Bilstein's you mention as we don't have enough information for what you're asking?
That will work just fine. I'd check some site sponsors as they may have a deal as well. I recommend energy suspension extended bump stops. They are only like $10.
What is the best way to level a 2009 titan crew cab 4x4? I want to do it the best way possible no excessive wear or damage to any parts. I've read the thread on it but I'm still a little confused.
thanks
