1 - 6 of 6 Posts
I broke the first valve trying to loosen it. I don't want to pay the stealership to remove if possible. Any ideas would be appreciated. I changed all the pads/ rotors with no problems thanks to Black Beauty's write up. Thanks. Joe
Can you post a pic of the remnant that needs to be removed?
clean with wire brush, soak in penetrant (Aero Kroil, PB Blaster, etc.), apply extractor like easy out, reverse drill bit etc. If you heat the caliper with a torch, you risk roasting the seals.
1 - 6 of 6 Posts
