Went to the Local BB tonight looking for just some info. Seems the best way to upgrade the system is to start with a better HU. Is it possible to keep the stock HU and just get better speakers? Would that even be worth it? Thanks for any info.
Three reasons to keep the factory HU
1. You have oem NAV
2. You have oem rear DVD player w/ rear controls
3. You are on a limited budget
Otherwise get a new HU. Note that steering wheel audio controls can be made to work with an aftermarket HU.
Brianyzf said:
Can you upgrade the HU while retaining everything else (speakers, etc.)?
the only thing you can keep if you change the headunit wouldbe speakers and steering wheel controls. You will lose rear A/V inputs and controls. You can't use the factory NAV either to my very limited knowledge.
Sure. But why? The only thing in this system that is R/F, IIRC, is a mini amp attached to the firewall up under the dash. The rest are Panasonic and Clarion components. The speakers could easily be upgraded to better units. There are dozens of threads on here about it.
It's a $$ issue. Can't afford an entire new system right now and since I really don't care for the look of the RF HU I would prefer to start with replacing that. For me the sound is just fine, I'd just like something that looks a little cooler. And I also would like an HU with a USB input.
