Fixed a common problem with our vehicles - the Oil Cooler Seal on my 2007 (Part that the oil filter screws onto) was leaking oil. Went to RockAuto for the new gasket and one of the parts that comes up is FEL-PRO 72493 {#21304JA11A}. Purchased the gasket and set it aside until the next oil change. During the oil change, I Removed the Oil Cooler and went to replace the gasket and found that the diameter of the Fel-Pro was slightly larger than the OEM and would not fit. I took both gaskets up to Advanced Auto and the guy behind the counter brought out the same Fel-Pro gasket which was the exact same (wrong) size as the one from RockAuto. He also had a Dorman brand for a few bucks more. That one fit perfectly.
Anyway its a $5 gasket so not a big deal but just passing along the experience to possibly save a few others the headache of having it all apart, only to have the gasket not fit! Pic attached - OEM is stacked on top. Subtle difference but enough that it won't fit!
