O.K. gearheads, here's a possible retrofit opportunity for the Titan. Question is, what would it take to make this 90mm Infiniti Q45 throttle body work on the Titan (70mm)?
Here's the auction for the item in the attached TB pic;
http://cgi.ebay.com/ebaymotors/Infi...QitemZ260025438532QQihZ016QQcategoryZ33558QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Here is the way to search to see these TB's on ebay;
eBay Motors> Parts & Accessories> Car & Truck Parts> Air Intake & Fuel Delivery> Throttle Body> Search Results for 'infiniti Q45'
Don't know if this address will work or not since it may involve my ID??
http://motors.search-desc.ebay.com/...QQmppfqyZcustomQQmppfqyZinfinitiQQsacatZ33558QQsspagenameZSTRKQ3aMEFSRCHQ3aSRCH
If the bolt spacing is different an adapter plate might be required for mounting to the intake, but would think someone can get the exact specs or excellent pics of this Infiniti TB vs. Titan TB to see what could be done to physically get this 90mm TB to fit the Titan. Other considerations are the vacuum/air fittings and the especially if the TPS connector harness will be the same (if not the pin-out specs would be needed.
