pro comp recommends using 5in. backspacing but all the wheel i like are 5.5 or more has anyone used a larger backspacing? if so how much?
Any additional width to the rim will go out not in.ptgarcia said:You could use a 5.5" b.s. wheel but you can't go any wider than 8" otherwise the tire will rub the spindle in front and the bump stop bracket in the rear.
