I have a 2006 Titan LE Crewcab. I would like to get larger offroad tires without spending the money for lifts just yet. Has anyone figured out the max tire size with stock oem equipment?
if you don't have a leveling kit then 33's are about it, with leveling kit you can do 35's maybe, but you will have some rubbing. There are lots of threads on this topic in the search if you need more info.I have a 2006 Titan LE Crewcab. I would like to get larger offroad tires without spending the money for lifts just yet. Has anyone figured out the max tire size with stock oem equipment?
If he had 20's, 305/55-20 seems to usually be the closest available to the the 325/60-18.Correct me if I am wrong, but the OP says his titan is an LE, shouldn't that come with 20"s? If so, a 325/60/18 wouldn't do him any good.
If you do the math on a 325/60/18 it equals: 33.35x12.79
So if you do have 20"s, you would want that equivelant, probably something like a 325/50/20; if that's even a real size, I just kind of made that up in my head...
You are wrong. He has 18s. Only the latest titans moved up 20 inch wheels.Correct me if I am wrong, but the OP says his titan is an LE, shouldn't that come with 20"s? If so, a 325/60/18 wouldn't do him any good.
Pass on the body lift because its a ton of install time and you would be better of going with a prg mini lifthey thanks for all yalls input, how about with a 3" body lift?
