Are you looking for wider or taller? Some people are able to run a 34.5", BFG AT KO, in a LT315/70/17 with just a PRG leveling kit ... without trimming. Others have had to do the pinch-weld-mod. So a bit of a gamble. All depends if you have an issue with using a Sawzall, (inside the fender, behind the liner).Talent said:Its about time for some new tires, and was wondering if I can go any bigger with a stock suspension. Right now the truck has 285/70/17? Can I go any bigger without rubbing?
So the Nitto Tera Grapplers in a 33.2", LT295/70/17 work w/o a level kit? That's cool if they do. They are slightly smaller than their cousin, the Toyo MT.Fox Delta said:hmm a 285/70/17 so you have a 4x4 with the off road pkg... - Nitto makes a terra grappler in a 295 that will fit -
well - I should say that they did fit on the front of my truck before I got the level kit - Discount Tire mounted the front two for me and let me drive around the parking lot - I had a little less than a finger's width of clearance (on my plastic inner liner) with the steering wheel at full lock on stock OR rimsNorCal 4x4 said:So the Nitto Tera Grapplers in a 33.2", LT295/70/17 work w/o a level kit? That's cool if they do. They are slightly smaller than their cousin, the Toyo MT.
That's probably enough for owners with a conservative driving style, that use their Titan only on-road, or slow on dirt roads. A level kit definitely gives a bit of leeway.Fox Delta said:well - I should say that they did fit on the front of my truck before I got the level kit - Discount Tire mounted the front two for me and let me drive around the parking lot - I had a little less than a finger's width of clearance (on my plastic inner liner) with the steering wheel at full lock on stock OR rims
yep I agree and that's why I started with the leveling kit-- its the way to go.NorCal 4x4 said:That's probably enough for owners with a conservative driving style, that use their Titan only on-road, or slow on dirt roads. A level kit definitely gives a bit of leeway.
Good info!
LTBs would be kool for those guys and gals that can afford dedicated tires, but I'm after a general purpose tire, that's good for the commute but isn't phased by hitting a 6x9 river rock at 50 mph. My current, BFG AT KOs have fit the bill, but have gotten slick in their old age. So I'm going to try an E-rated, Toyo AT or MT, (with aftermarket sipping).Fox Delta said:yep I agree and that's why I started with the leveling kit-- its the way to go.
BTW Interco tire makes a 34x10.50/17 (it's the LTB tire) that would fit with a leveling kit on stock OR rims too - it's an agressive tire though
shukart said:im looking at fitting a 305-R18 tires with a leveling kit, will it work or 295-R18?
The new brakes a fine IMO, and I've put about 40K miles on them, most of has been with 58lbs. BFG AT KOs, (stocks were 43 lbs.), and on very curvy roads with lots of braking.powdercoat said:I would be cautious of any extra wear on your brakes. The more weight you add will only cause premature wear. It's not like we haven't had enough brake issues![]()
Yep, there are hidden costs with most of the upgrades, and it's good that you brought it up, especially being a safety issue. Also, some might not notice it that much until they are towing or heavily loaded, (their truck bed :upsidedow ).powdercoat said:I say bigger the better but consider a brake upgrade if you haven't already done so. I see these hip hop guys everyday who put huge rims on their cars but they can't stop em.
Yep, I mentioned the BFG earlier.Masher500 said:i thought you could use the nitto with 325/60/18 and it wouldnt rub?? also bfg 305/65/18 both are 33s i think. Someone please correct me cause thats what im asking for xmas, and i dont want the wrong set up.
As far the Nitto it might fit w/o rubbing but the stock rim is an inch and a half less width than the recommended 9.5". It would probably pull in to be 12.23" wide, but would likely flex, and feel a bit unstable, especially because it only has a two-ply sidewall and is a D rated instead of an E-rated tire.BFG AT KO LT305/65R18/E 33.7"x11.8" on the stock rims.
