Biggest tire size, no lift?
39308 Views 22 Replies 12 Participants Last post by  bollingeralx
What is the biggest tire size you can use on 18x9 wheels on titan with no level kit, just stock? Anyone know with little or no rubbing? Can I fit 285/65/18 tires?:brownsmil
1 - 20 of 23 Posts
Use this site for tire size calculations.http://www.powerdog.com/tiresize.cgi
285/65R18's are the same size as our stock tires.
Not really sure on 18x9 wheels, but mine are 20x9 and I'm at stock level with no rubbing issues.
Thanks Alot!! I'm using black XD Diesels 18x9 with 285/65/18 terra grapplers. Time for some sand time on the beach!:cow:
With the same offset as OEM wheels, you can fit 325/60-18 with no lift but the 285/65's stay tucked underneath the fenderwell a little better.
i am running a 305/50r/20. they fit great and have no problem rubbing.
Well here they are 18" XD Diesels w/ terra grapplers 285/65R18... time for some off roading on the beach!
Sweet! Good Pics... Going To Do Any Performance To Turn Those 33's?
325/60/18 on 18x9 will fit with a mini lift
I have a Brute Force cold air intake w/ Flowmaster dual exhaust...plenty of power!
Those tires look great! I think that's the tire I am going with after these POS Goodyears are done...won't be long. Nice looking truck.
Did you have an exhaust shop do your exhaust for you or did you get that through flowmaster?
I've got a set of 305/55-20 bfg at ko's, approx. 33.4", not on truck yet but I might try to put them on before I raise the front of the truck to see if they would fit.
I went to a custom shop who custom bent the pipes w/ flowmaster muffler and stainless silver line tips. You should be able to fit those tires I have plenty of room.
i have a 2008 crew cab se 2wd titan...what are the biggest tires i can clear with a leveling kit and a little bit of rub is fine.
I would go with some like mine for the largest if I were you but you can fit some 35x12.5's under a Leveling Kit. The Pinch Weld Mod would be a must do for Mud Grapplers.
Will 35x12.50R17 Procomp Mud terrains fit under a 05 SE Off-road without a lift? I want to get the lift later but just don't have the money and I need new tires.
With a level kit, mudguard removal, a major pinch weld mod, maybe, but even a 34.5" LT315/70R17 A/T usually requires some trimming.
Totally stock, and no trimming you probably can't go over a 33.2" LT295/70R17 A/T, or a 33" LT285/70R17 in a M/T.
Some of the LT305/65R17s that are usually around 32.8", or the 33x12.5R17LT's would also work ... I saw a Kumho that was only 31.6" diameter, and how they can call it a 33x12.5 :confused:
1 - 20 of 23 Posts
