1 - 2 of 2 Posts
Thought I'd share a little mod. I did the "Utilitrack Yakima bicycle mount" years ago to the track behind window. Didn't want to remove the shell this summer but wanted to mount bikes in bed for camping/rd trips. Found a couple of "T" brackets in the strut/channel bin at work that turned out to be perfect for this. I drilled a hole in the middle of bike mount with the intention of bolting to bracket and spring nut...but the Yakima mount curves over the new hole too much to slide in the longer bolts I had on hand. So it only has one bolt holding it down to strut/channel as of now. The link below shows the tee bracket. I placed the tee where there is a "bubble" in the bed around channel to fit nuts. It ain't prefect yet but will get the job done this summer
Flat Plate, Channel - Strut Channel Accessories - Conduit Mounting - 5YE23 : Grainger Industrial Supply
1 - 2 of 2 Posts
