1 - 14 of 14 Posts
This is the Yakima rack made by Nissan for the Xterra. I took off the feet and clamped it down using the cleats and security bolts.
Pros: Easy to install and remove. Sturdy/Secure.
Cons: Currently not theft-proof. need to drill holes in Yakima bar and secure with cable lock.
Super Moderator
Cons: Currently not theft-proof. need to drill holes in Yakim bar and secure with cable lock.
Very clever!!! Simple and easy to purchase, good thinking TITANTX! :teethmast
One more thing...
When you're done hauling the bikes, just unclamp the bar and put it behind the back seat. Only takes a minute to install it or remove it.
That is truly a great idea...thanks for posting it. I generally "southern engineer" my stuff...in other words, to secure my bike I would have used a roll or two of duct tape. Oh how I love my duct tape and wd40. BTW, McGyver is my hero. :)
gtshouse said:
Here's a mount that I made. Similar to someone else's on here.
How did you remove the screw from the stopper thing? When I try to unscrew mine, it gets stuck at the end of the screw. I could force it (I guess), but I don't want to break it.
I was able to "coax" it out with a pair of channel locks and the factory wrench. It took a bit of patience to get them threaded again, but all is well now! I noticed that it got easier the more I removed it and re-threaded it. Whatever mutiliation they do on the ends of the threads takes a few times through the nut to straighten out. It would probably go quicker if you had a die to clean them out with.
Hello Everyone,
As you may have noticed in a previous thread, our company CCR Sport is coming out with a line of really cool accessories for the Titan Utilitrac system and one of the items is a bicycle fork mount. We will have the prototype completed today and we will post a picture and details next week. Please stay tuned.
Thanks
CCR Sport
626 695-1218
www.ccrsport.com
Very nice :)
I appreciate you sharing with us, your setup looks very professional, I am sure others will like the same setup. :cheers:
I did the same thing silver serfer did...channel locks and the factory wrench. I did break one of the bolts before I was finished though. When I have time, I will try to find another bolt that will fit. I didn't have any trouble threading mine back in, but it's still very very tight. I have to use the factory wrench almost all the way....I can't turn it with my hand until I've got it almost screwed all the way in.
TitanTX,
Does this bike rack continue to work well for you? I need to get 4 bikes mounted in the bed and your solution seems like the only one that will work. I've seen the 58" racks online, do you know where I can get the bracket and fork mount?
vw3vr6 said:
How did you remove the screw from the stopper thing? When I try to unscrew mine, it gets stuck at the end of the screw. I could force it (I guess), but I don't want to break it.[/QUOTE
I used a hacksaw and finished it with a dremel. Just make sure you lube the threads before removing the little bracket. I unscrewed it until if felt tight and backed off a little bit. Took about 5 minutes but it works fine now.
Discussion Starter #14
motoman,
Yes, it works fine. I leave the bolt-ons in the tracks and the rack and cleats behind the back seat.
I'm not sure where to find the bracket and mounts - probably from Nissan. They were part of the Xterra interior bike rack.
1 - 14 of 14 Posts
