1 - 1 of 1 Posts
Bilstein 5100 Series Shock Package
2004-2015 Titan 4WD
SKU: SPACBIL5100SSPKGT
Free shipping within the United States(Alaska & Hawaii Included)
$345.00
Description
The front zinc-plated shocks that install like factory replacement shocks and are designed to correct the factory rake.
The OEM spring seat is repositioned to provide more preload to the factory spring.
The result is a close to level front to rear ride height.
Front shocks provide 0"-2" of lift. Increments of .5"
The rear Bilstein gas pressure shocks use monotube design which dissipates heat more effectively than a twin tube shock for cooler, more efficient operation and longer life.
14mm hard chromed piston rod.
The lightweight one piece rod guide is made from a unique aluminum alloy that maintains a nearly friction-free surface for longer life.
The superior seal design keeps dirt out of the working cylinder and prevents failure even under severe pressures of up to 2150 psi.
The piston head design allows independent tuning of the compression and rebound damping forces to provide optimum ride comfort and performance without compromise.
Patented digressive valving instantly reacts to changing surface conditions for maximum comfort and control on and off road.
Rear shocks can be used for 0"-1" of lift
1 - 1 of 1 Posts
