Tonight I finished the rear installation of the Bilstein 5100's. Not much really here as far as installation process goes. Its real easy to do the rears.
-PB Blasted all 4 bolts about 4 days prior than tonight, each night.
-I jacked up the rear of the truck
-Put jack stands on each side under the frame. In front of rear tires.
-Pulled the floor jack under the driver side of the axle
-I put a small 4x4 piece of wood on the jack and jacked up the driver side axle ever so slightly from under the bracket for the leaf spring. Just enough to slide the bolts out from the shock mounts.
-Removed the old shock from driver side
-Started from the top shock mount with the new Bilsteins
-Ran that bolt through and hand tightened that bolt
-Lowered the jack ever so slightly to line up the bottom shock mount
-Ran that bolt through the bottom and hand tightened
-Repeated same process above for passenger side
-Went back over all 4 bolts and torqued them to 115ft lbs.
-DONE!!! :rockon
I will try my best to get good pics and try to do a step by step for the front Bilsteins installation tomorrow. But, here are some pics of the new shocks vs the old crappy rusted Ranchos. These Ranchos are garbage. The dust cover is a hard plastic. They just feel very generic compared to these Bilsteins.
