You might want to try removing the preload. It will lower it 1" in the front from where it's at now, but the tires should still easily clear with stock rims. Then if this solves the issue, and you don't like the rake, get the PRG adjustable shackles and drop the rear 1" or put on a 1.5" PRG leveling kit, which will lift without the additional preload.
As for the tires, if you can exchange them for something else, do it. Although my Terra's handle the curves pretty good, they have poor traction and are not as smooth as even my M/Ts were.
