Well it finally warmed up enough for me to pull my grill off and put these inserts in. It said it would fit without cutting the mesh out of the stock grille but I sized it up and I thought it looked kind of silly with the mesh so I cut it out with a Jigsaw.
Tip to anyone who does this, it is well worth the extra two minutes to seperate the two pieces of the grille to cut it. I tried cutting it with them together first but came close to clipping the shiney parts with the saw so I seperated them.
The install was overall very easy, only tedious part was getting it back on the truck. Those little factory clips across the top are very anoying so I took all of the upper ones out and used heavy duty Zipties. the lower and side clips went in no prob.
