I checked the passenger side it was beginning to leak also, the area around the seal was wet. I don't know if this was a factor in the dealership deciding to replace the whole rear axle.BillR said:Nice deal. They replaced my seal, bearing, and collar on the driver's side.
I had to tell the dealer to put a rush on the axle because I am going on vacation next week and didnt want to drive 900 miles with a leaky axle.Carbeaux said:They're only doing the seal on mine. I'm scheduled weekend after next.
I wish I could man but Ive spent my mod money for the next couple of monthsTitanBlue said:Now you can do the Truetrac afterwards!![]()
dksfowler said:just had my passenger side replaced this week. and theyreplaced seal baering and collar thats all.
Take it to the dealer and get it fixed ASAP.2008 titan se crew said:I just bought a 2008 Titan SE Crew a couple weeks ago. it now has 830 miles on it and the driver side rear axle seal appears to be leaking. this is my first Titan. Should i be worried about the reliability of the truck. It also has the A/C drain problem.
I took my titan in a few times for some minor leaks etc, But ever since it was fixed no problems. Just make sure you work out all the kinks before your warranty is up2008 titan se crew said:I just bought a 2008 Titan SE Crew a couple weeks ago. it now has 830 miles on it and the driver side rear axle seal appears to be leaking. this is my first Titan. Should i be worried about the reliability of the truck. It also has the A/C drain problem.
Why do you think it doesn't breath in both directions?Justintoxicated said:I am going to bet that most of the axle seal leaks are because of that stupid one way valve on the diff. It needs to breath BOTH directions WTF!
Learjet said:Why do you think it doesn't breath in both directions?
I don't think the metal cap on the vent can seal the air from going in the axle.
Not really, the particles are fine enough that they are just floating around in there, until the magnet picks them up. I'll stand by my opinion that the axle vent is the problem.Learjet said:Do you think the metal and crud we see everytime when changing the diff fluid could be enough to eat at the seals and ruin them?
