bolt pattern ?
2979 Views 2 Replies 3 Participants Last post by  54warrior
Hi
I'm in the market for new tires and 18 inch wheels .
What bolt pattern will fit titan ?
thanks in advance
1 - 3 of 3 Posts
Typically the same lug pattern as the Chevys.
6x5.5" or 6x139.6mm
You will need to pay attention to wheel offset and backspacing to assure proper clearance with suspension components.
It's usually not the suspension components that interfere as often as it is the area of the front fender/body directly behind the front wheels. Certain wheel/tire combos will require that you perform the "Pinch Weld Mod". If you do a search on that you'll find plenty of info.
It is certainly possible though to have interference issues with the spindles/sway bar though with the incorrect combination.
1 - 3 of 3 Posts
